line fell off
skip15
my boat stopped at wot come to find out the primer fuel line came off does oil still go to the cylinders after this happens because the motor will not start it labors to turn over all i can figure is the line came off and it got no gas but filled the cylinders with oil and this is why it 's doing this
GA_Boater
It would help to tell us what motor because there are primers, primers and other primers - Each works differently.
boobie
When you say primer fuel line, are you talking about the main fuel line coming from the fuel tank ??
skip15
it's a 1993 johnson 115 it's the small 1/8 line that attachs to the bottom of the primer
That primer line only comes into play when you are starting the motor.----No fear and no worries.-----Fix the reason for that line falling off and go fishing.
