Hello. I have a 1981 johnson 70 hp and now finally getting a manual I've done the link and sync and timimg. I found top dead center with a homemade piston stop tool and found the pointer was about 2 degrees retarded from where it should of been so I adjusted and measured, and measured and measured many times to make sure it was spot on
now to warn, I read alot of post saying that not to mess with it as its probably right from the factory. And at the lake I was really testing it for confirmation. As all the post on here about not messing with it could mess up your engine kinda worry me.
I got it to the lake and going wot it was reading 16 degrees, where it should set at 19. Now I bought this motor used, and its had its little things that didnt seem right like the spark plugs had been replaced with a much smaller plug and no crush washer. Stuff like that I found so its not out of the picture that this may of been messed with.
Anyways. Just want confirmation that I've done everything right and maybe stuff to look for that could have caused an error. After getting that reading I took it home and measured tdc again, and a few more times just to be sure. Really just any insite on potential mistakes.
thank you !!!
thank you !!!
