Link and synch question
jhogue46140
I have a 1988 mercury 150 xr4 and am doing a link and sync. Anyone know what the primary throttle pickup is? Seloc manual online shows 22 degrees ATDC while it shows others are from 7-11 degrees atdc. Is this correct?
Thanks Doug
j_martin
Re: Link and synch question
Set it at 10* to start with. It is changed when you set your idle speed, but it will be near there.
Max timing at idle is 19* with the advance module, 23* if you took it off.
I've run mine both ways. Presently the advance module is next to the chit can. WOT is 23*. Runs good.
Hope it helps
John
jhogue46140
Hi John,
Didn't think you would be on this late that is why I posted a separate post. Thanks for the help.
