Link to trim adjustment
Hvymtl
Where can I find the link to the Alpha I Gen II trim adjustment? Once I get that squared away, do I adjust my trim guage so it matches the max up or down condition or is there another adjustment?
Hvymtl
Re: Link to trim adjustment
Page 4a12 the trim sender is located on the pump? Or the gauge itself?
I think I figured it out..standing at rear of boat the trim limit is on the left and the sender is on the right -- correct? I was thinking these were both trim limits and the sending unit was on the pump...wrong from what I found in my searchs.
Don S
The trim sender is on the gimbal ring. The gauge is on your dash.
Ayuh,..... The Most useless gauge on a dash,...
The Seat of yer Pants is a much more Accurate trim gauge....
No senders at the pump at all...
Hvymtl
Got it - thanks! I'll set the ram arm to specs (20.75) using the limiter on the left of the outdrive (standing behind the boat). I can recalibrate the trim guage with the position sensor on the right of the outdrive
