Re: Linkage?
Disconnect cables from the engine and test cable movement when operating the remote.
If ok, set engine and remote in neutral, , adjust trunnions on cables so the cables just fall in place, retest.
Fine-adjust shift cable so the angle of movement in the handle is the same from neutral to reverse and neutral to forward.
Fine adjust throttle cable to be sure it goes against idle stop.
