Re: Little help Identifying this drive?
The Gen II cable is the same as the older Alpha cables and can be used in place of the old style cables.
This shows how the old and new style cable mount in the bellhousing.
To use the new style cable, you need to tap the threaded hole out with a special tap, and use an an OEM cable, not an aftermarket. Well worth the extra few bucks, plus they last longer because of the teflon cable. If they keep impellers in them so they don't melt.
