when starts it quits shortly after, I replaced the plugs and bulb, as I would need to pump it to keep it going. Fireman you said to replace line do I really need to, and where is the fuel pump, I will get a friend to help repair, if not chuck it.
Re: "little lady", needs an answer, evinrude m#9322b,ser#c88746 what y
You have a 1973 9 1/2 hp. Are you using fresh gas & oil? Hose may not need to be replaced. Does the bulb stay hard after you pump it? Does the gas can have a vent screw and is it open a couple of turns?
Hi, Kimberly.<br /><br />Do you have a manual? If you plan to work on your engine you need one.<br /><br />Did you have an earlier post on this same problem?<br /><br />Please stick to one thread. If we can't get all of the information in one place we will end up spinning our wheels and wasting your time and ours.<br /><br />Sounds like you have a fuel starvation problem.<br /><br />Please fill us in on what you know that isn't in this thread.
