I have an Evinrude 9.5h.p., model#9322B, ser#C88746 what year is this. It starts and stops and I have to keep pumping the gas into it. What might be the problem? If its the fuel pump, where is it located?
Re: "little lady" needs to know yr. evinrude9.5hp. m#9322b,ser#c88746
probably a bad fuel line. If your primer bulb goes soft while you are running replace the line and bulb (WalMart - 20.00). If not you will need to rebuild your fuel pump. Are you planning on doing this yourself?
