Re: Live well drains when under way
VB Fishing,<br /><br />You have to close the well off, in some manner for it to hold water.<br /><br />Running the pump all the time is not the answer.<br /><br />When using the pump to add water and keep it fresh, the bottom drain should be plugged. The overflow will exit out of the standpipe.
