live well pump question
jlsmith
I recently bought a 98 pro team 175 bass tracker. I need to reseal my thru hull connenction for the live well drain. Problem is it is located under the aerator and recirculator. But I cannot seem to remove the pump to get to the nut on the thru hull. The pump and recirculator is connceted to a thin metall bracket that is riveted to the the hull. Any ideas on how to remove the pump and recirculator. I have removed the hoses and have tried to twist the aerator pump but don't want to break it. I do not see any screws. Any help would be appreciated. Thanks
5150abf
Re: live well pump question
It is super fun working in the bilge isn't it.
There has to be screws or a nut and bolt holding the pump on the bracket, the pumps I have seen have them on the back of the pump or on the base, not actually seeing what you are working on makes it kinda hard to geuss but there has to be screws holding it on.
yuh,... Cross posting the same question in multiple forums is frowned upon,...
We all read most all of the forums, 'n it creates Confusion...
