Live Well Valve Question
DuckHunterJon
Just under the shift/throttle control, there is a small lever that says Live well fill/drain. I looked behind the control and saw a cable that led towards the back. In the bilge, I found the other end of the cable attached to the arm of a valve in the line that goes to the livewell pump. Problem is the cable is froze up. I'm going to remove it and see if I can put a cable luber on it, but it I can't free it up, does anyone know where I could find one that long. I haven't pulled it out yet, but I'm guessing it has to be over 10 feet long.
Thanks.
DuckHunterJon
Re: Live Well Valve Question
Thank you for the info. Gives me a place to start! Off to google I go.
