Re: Live well
First, the boat needs to be in the water to test the live well. Second, the pump needs to work. The pump takes in water through a port at the stern. Pumps it to the areator head in the live well. There are a couple different types of live wells. If the live well has an overflow near the top of the tank you need a plug for the drain hole in the bottom. Water fills the tank and then overflow goes out the top. If there is no overflow, then you need a standpipe that sticks into the hole in the bottom of the tank. The pump then fills the tank and overflow goes down the tube and out the drain. If you don't understand what a standpipe is, take the lid off your toilet. The pipe in the middle is a standpipe.
