Live Well
wvcatfish
How can I put a live well under on of my bench seats? I've got a 21 ft party barge and was thinking of putting one in under one of the seats and using a bilge pump to fill it mounted to the back of one of my toon. anyone ever done this? What did you use to make it with and a pic would be great of the finished project.
old jim
Re: Live Well
On my party barge (03 18ft ) the live well is under the driver's bench.
Did you look? Regards, old jim Hope you understand this is very toung in cheek.
wvcatfish
Re: Live Well
laughs its a used boat.. there is a bilge on it that was shoved up under the deck but it doesnt go anywhere. saw one at east lynn that had one installed in it it was nice. I'd like out a way to put one in my boat
Silvertip
Re: Live Well
Live Wells need a tank. Find one that fits in the space you have. Any plastic container -- even a bucket can be used. Cut it down to whatever height you need. Cut a hole in the bottom for a through hull fitting and one through the side for an overflow. The overflow can be eliminated if you use a standpipe in the drain. If you don't know what a standpipe is, raise the lid on your toilet tank at home. That pipe in the middle of the tank is a standpipe. If the water gets too high it runs over the top and down the drain. A bilge pump can be mounted on the bracket at the back of of one the tubes. If you don't have such a bracket, any welder in town can weld one on for you. The pump feeds water to a spray nozzle or bar in the livewell. A simle on/off or a manual/auto timer switch can be used to operate the pump. Everything you need is available right here on iBoats.
MH Hawker
Re: Live Well
I made one for mine but made it a free standing one in front of the helm I didn't want to lose storage space. the pictures and in the rebuild thread in my signature.
I use to do a lot of fishing there at East Lynn. but I have moved to beach fork because I can slip my boat there.
BobGinCO
Re: Live Well
My boat came with TWO livewells! I removed one for more storage space.
old jim
Re: Live Well
Over on page 3 there is a post started by seamanew titled i think does anyone know of a good drop
in live well? you might find some good info there. sorry for my computer ignorance. old jim
