Livewell Aerator Problems
7lazy77
I am having problems with my Aluminum boat's manual aerator blowing the 5A fuse immediately after I flip the switch on. Where & how would I begin tracking down the problem? Electrical is NOT my strong-point! Any help is greatly appreciated.
Re: Livewell Aerator Problems
Ayuh,.... It's probably the pump itself, so start there,...
is the impeller free of crud,..??
MH Hawker
First thing to do is disconnect the pump and put in a new fuse and flip the switch, if it blows, its in the wiring, if it dosnt replace the pump.
Bob_VT
Sounds like an electrical issue. (I moved the thread) Depending on the age of the pump...... I would change the fuse and DISCONNECT the pump to check the voltage at the pump end. That will eliminate if you have a short in the switch which is possible. If needed remove the pump and try it separately.
If it is the pump then look at what iboats has available ;) Livewell Aerator Pumps & Live Bait Wells - iboats
