Re: Livewell Aerator Question
Well, there is a timer switch on the bow panel, and since I really don't know the history behind it, it may be possible that the original switch may have been replaced. The aerator does come on for about 30 seconds and pauses for different intervals of time depending whether I go to min or max or somewhere in between. I'm confused, as I don't know whether or not the dial would have anything to do with the operation. Maybe I'm just too picky, I don't know.
I do however, have another issue that you might be able to help me with. My bass boat used to have a 6 terminal 3-way toggle switch installed to select Battery 1 or 2. The switch was broken, (probably stepped on by a previous owner), and disconnected. Since my trolling motor is strictly 12v, it would be awesome if I could put in a new switch and select a battery from the front fishing platform instead of crawling to the stern and switching trolling motor batteries 1/2 way through the day. I have 1-8ga Orange wire, 1-8ga Red wire, and 2-8ga black wires that run from the battery compartment to the bow of the boat. Can you tell me where I can get the switch and a schematic on how to wire it? What I need is a way to separate the 12v leads and use them 1 at a time at the flip of a switch. With that said, I'm not even sure if I need 6 terminals either. If I could get a switch that would make a connection 12v in on one side and 12v out on the other at the top and vice versa on the bottom with the off position in the middle, I would have everything I needed. As always, I appreciate your assistance. Thanks!
