Matt Dingman
- Joined
- Jun 24, 2008
- 14
I have recently put the livewell back in and got everything plumbed back up and wired. My wife and I catch and release (not fish-eaters) so we have never used the livewell. To be honest I couldn't tell you if I ever tried the switch before rehooking everything back up. I have 3 hoses running to or from the livewell. One comes from the back of the boat and is the filler. One is the overflow as it runs higher up the beltline of the boat and exits driver right. the other hose exits below water line right under the overflow outlet (drain?.) The fill line from the stern runs to the livewell into a brace of jets similar to what you would see on a pull-behind garden sprayer. HOWEVER, in line with these jets is a 'T' connector that drops down into the tank with a bilge pump hooked up to it. RUNNING INTO THE SAME LINE as the fill. It can't pump water out of the livewell into the jet bar and back down the line to the stern intake/pump in the back can it? I am pretty darned sure it's not an aerator as it says "bilge pump" right on it @450gph. Any help would be greatly appreciated. Thanks!
Matt
nmtatersk@netzero.com
Matt
