I'm in the planning stage for a rebuild of a 14.5 ft. tinny. Boat is 66" wide so I'm making it a center console, with a forward casting deck and a livewell. The old deck is out and I want to run all the wiring and plumbing before putting the new deck down. I'm going to locate the livewell in the casting deck or under the forward seat in front of the console. Where should I run the pipes? I understand the drain has to be low on the outside. Can I plumb it out through the transom or is there a better place? Whats the best location for the intake line? Should I run 1/2"or 3/4" lines? What is the best location for the pump? I've looked at several set-ups online and they appear to vary greatly. Appreciate any advice.
