Ok, if I am building my livewell, do I just put a hose or pipe that comes through the livewell at the level I want it to start draining and make sure that the hose is lower on the hull of the boat so it creates a gravity effect for the water to drain out?
Obviously it has to be above the water line on the side of the hull, but is it ok to do what I said, just make sure the hose in angling down so it drains out?
also, do most people screen off the over fill drain so that you dont lose bait?
thanks
thanks
