andrewsailor
- Joined
- Jun 9, 2009
- 57
I have an alumacraft classic and when i go to use the livewell I open the valve in the tank,switch it on and can here the pump running,however no water runs into the livewell.If I fill the livewell by hand until I can get water to flow down the infeed head and switch the pump on it will work fine until I move the boat again,then I am back to square one,the dealer tells me to drive the boat backwards to force water in ,but this dosen't seem like a solution.There are no blockages since the pump works when primed from the livewell end.The pump is below the water line so shouldn't it prime itself,i've tried switching in on and off a couple of times but still nothing.....
Any ideas anyone
Any ideas anyone
