After turning off my 200hp johnson after wot or close to that, does not want to start back up the first time i try and sometimes even the second try. I have even sat at idle after the runs to help cool it down slower [so I was told thats what it does] and have putted at slows speed to but that does not seem to work either. A mechanic told me the carbs were probably loading up. When it starts after the runs it smokes, spits, water pressure is very low then dies in about 3 seconds. I let it sit for 30 seconds and then it starts up slow, but then kicks in. If i give it gas in neutral it still smokes alot but 3 quarters of the time will keep running. Any advice about if this is what they call loading carbs, and how to correct the problem
