Re: Location of Model and S/N on old Johnson Sea-Horse
This is what will tell you the year (if you find them):<br />5 HP <br />AT-39 Johnson 1939 <br />DT-39 Johnson 1939 <br />LT-39 Johnson 1939 <br />AT-10 Johnson 1940 <br />DT-10 Johnson 1940<br />LT-10 Johnson 1940 <br />TD-15 Johnson 1941 <br />TS-15 Johnson 1941 <br />TD-15 Johnson 1942 <br />TS-15 Johnson 1942 <br />TS-20 Johnson 1946 <br />TD-20 Johnson 1946 <br />TD-20 Johnson 1947 <br />TD-20 Johnson 1948 <br />TD-20 Johnson 1949 <br /><br />1950-51<br />TN-25 <br />TN-26 <br />TN-27 <br />1952-53<br />TN-28 <br />1965 <br />LD-LDL-10 <br />1966<br />LD-LDL-11 <br />1967<br />LD-LDL-12 <br />1968<br />LD-LDL-13 <br /><br />Sorry about the long list.<br />A picture of a 1966 5 HP:<br />
http://mitglied.lycos.de/old_omc/j_1966/seite_07.jpg <br />And a 1968 5 HP:<br />
http://mitglied.lycos.de/old_omc/j_1968/seite_20_21.jpg <br /><br />No the numer is not on a decal. Should be on the transom mount bracket on a rivioted on plate. If the plate is gone then look under the engine cover. On top of the powerhead behind the flywheel you should find a freeze plug. The Serial and model number will be stamped into the plug.<br /><br />Good luck!<br /><br />/Bear
