Re: Location of Water Seperating Fuel Filter on MC Alpha 1?
The 3.0 has a fuel filter inside the fuel pump. The "canopy" of the fuel pump can be taken off, and there is a filter inside of it. There is also a strainer at the inlet to the carb. You need to unscrew the fuel line from the carb, and the strainer will pop out.
So, your engine DOES have a fuel filter. But, the better, fuel/water separating type is an option. You can pick up a kit for $30 to $50 to add one yourself. It's highly recommended. The filter is much bigger than the one in the fuel pump, and it is very easy to change out. Plus, the water separating feature is nearly a must for boats.
If you follow the rubber hose from the fuel pump back to the fuel tank and do not find something that looks like an oil filter, then your boat does not have the fuel/water separating fuel filter.
