1993 - Johnson - 88 Special <br /><br />A couple of weeks back I pulled my lower unit to replace the water pump. Today I got busy cleaning off the unit getting it ready for me to replace the entire water pump unit. That was when I noticed that I can nolonger shift out of forward into neutral or reverse using the rod. <br /><br />I've never had any shifting issues and I was very careful not to bump or put any strain on the drive shaft and shift rod.<br /><br />Any clues? <br /><br />I drained the l/u prior to dropping it two weeks ago. After running into the 'new' issue with the shifter rod being seized, I filled the case back up. It didn't help but letting it sit over night. <br /><br />Appreciate any suggestions.
