my70johnson
- Joined
- Jun 17, 2007
- 5
My son and I restored a 77 Lakecraft pontoon, restored the boat - not the motor. The 70 Johnson (I believe to be an 84 model) runs OK, if it starts. I am having a problem I have seen discussed in another thread on a different motor, wondering if it could be the same.
It is stuck near neutral - will go forward all the way down. I took it all apart, didn't seen anything that looked out of place, put it all back together, it cranked right up, went into forward, reverse (with some shuttering) but worked and I tooled around the lake for a while, shut down, then just to see, bumped the starter and it fired right off.
Next night my son goes back to the boat, slides in the key and nothing, not a click. He checked to see if it was in neutral and found it was locked again, out of reverse - goes into forward no problem. I saw one of the threads that suggested it was a nylon part with 2 "teeth" which I saw when I had it apart. Could this be the same problem? I've taken the cables off on the engine end and the shifters work fine on that end - so I believe the problem is in the box somewhere. I suspect that if it isn't in a perfect position the button isn' t compressed on the "no start in gear" box so this is why we aren't even getting a click (except the remote choke will click if you push in the key).
I need some help here please - summer is slippin away as fast as the water in Lake Lanier
