locktite or no locktite?
Benny1963
putting my midsection back together.
150 evin / the large main shaft has a 17/8 nut at bottom .
does this nut require locktite.or will simply torqueing it do the job
thanks everyone
Bennyb
Ranger 330V
Re: locktite or no locktite?
I would think torquing to specs would get it...someone will chime in though. Locktite sure makes you feel better and I don't see anything wrong with it, you can still get them off....just ALOT harder. :D
rjezuit
Make sure you use the service removable type, otherwise you will have to heat it if you ever want to get it apart. Rick
Gary H NC
On mine Benny everything has Loctite blue on it.Maybe Dhadley or Ezeke will chime in.
Dhadley
I use red Loctite on mine. On performance motors we even put a small tack weld on the nut so it can't possibly move. An overkill for a recreational motor but we don't want any play in a race motor.
rjezuit
The blue is considered service removable, with normal hand tools, and won't vibrate loose. The red is considered permanent and is usually used to hold studs into mating parts. The red can only be removed if you heat it. Take your pick. Rick
Benny1963
thank yall. red loctite it will be .
every bolt on this thing needed heat .salt water motors are a mother.
thanks Bennyb
