Loctite PL - what kind to use?
NatedoggAZ
I bought 2 different kinds of Loctite PL today to possibly work as a sealant/glue if needed.
I was surprised they had the Marine type at Home Depot:
https://www.homedepot.com/p/Loctite-PL-Marine-10-fl-oz-Fast-Cure-Adhesive-Sealant-2016891/206156418
They also had the regular Premium kind:
https://www.homedepot.com/p/Loctite...thane-Construction-Adhesive-1390595/202020473
I bought them both - can take one back if I need to...
Am I spending 3x as much on the Marine one for nothing though?
Thanks!
ND
froggy1150
The regular one is for bonding things like wood to wood. The marine is more of a sealant adhesive. I would use that for things submerged and the other for making stringers
NatedoggAZ
Coolio - I'll take the marine one back then - thanks!
It will be used to bond stringers if necessary - and the edge of the decking to the hull if necessary, around the edges.
ND..
dingbat
The marine is water proof. The regular is water resistant....big difference.
I personally would not use anything water resistant on a boat.
Woodonglass
I recommend taking both back and NOT using PL at all. Peanut Butter (Thickened Resin) is cheaper and better for all boat work. But...I AM just and Dumb Old Okie!!!!:D
