Re: Loctite
Willy, interesting to run into you again.
When you mentioned that OMC products are rebranded loctite, would this be Quickloc for blue and Ultraloc for red? Also, does loctite have any anti-corrosive properties? <br /><br />I'm finally coming to the conclusion that OMC Gasket Sealing Compound has a bit of thread sealer, corrosion inhibitor, and thread locker all in the same package. When in doubt, use the Gasket Sealer? I can't think of a case where using gasket sealer on threads would do any harm. I'm paranoid about corrosion/seizing on those aluminum alloy engines and the factory manual doesn't always specifiy what to use.<br /><br />At my local dealer, a mechanic said he uses loctite or OMC Gasket Sealer for just about everything. He puts in the head bolts dry. I understand this is to get the correct tourqe out of them, but for saltwater use, those bolts will seize for sure!
