Log damage
farmer9009
Well it was a great day out on the water until I found a submerged log floating down the river. It ripped the lower half right off. I was cruising at about 20 MPH when it happened. I felt it hit and immediately the RPMs shot up. I had my hand on the throttle and was able to quickly throttle down and turn the engine off but obviously the damage was already done. I know I need a new/rebuilt stern drive unit. I am looking for advice from people who may have had a similar collision and if they found anything else damaged besides the stern drive.
I have checked the hull for cracks and can?t find anything. The transom was rebuilt this year with new wood and is solid.
My plan is to pull the drive check bearings and alignment and install a new drive.
Also how often does this happen? I have never personally seen any fellow boaters hit something that actually broke the stern in half.
Photos included:
89mercruiser
Re: Log damage
I've never seen anything like that before. That hurts seeing that, see if your insurance would actually cover something like this. My parents told me that our policy covers the engine and outdrive.
picklenjim
Re: Log damage
You may want to remove the bottom half and have it inspected for damage. It may be reusable. You can get a top half new from SEI for $650-$750 depending on what year it is.
n2thex
Re: Log damage
WOW!! I hit a log last weekend and was pissed about trashing a prop and a hydrofoil. Now I feel fortunate. Sorry for the bad luck
Stamey
Re: Log damage
My Dad's boat has hit a log before. Insurance covered it. Damage was bad enough that they wanted to total the boat, but he got the money and kept the boat.
Chris
farmer9009
Re: Log damage
Well I put a dial indicator on the lower drive shaft and prop shaft and they are not bent. This is some good news.
I drained the oil and a small amount of water was present so I filled the lower with fresh oil and re drained.
I will be purchasing a new upper later this week and be back out on the water soon.
Aatcman
At-Sea-Man
Re: Log damage
WOW -- that's incredible -- never seen one fail like that!! -- Must have been a preditor log :D -- Your prop will need to be replaced or repaired too....
badkins50
Re: Log damage
wow farmer, glad everyone is ok. from the looks of it that had to of been a pretty good force. it's good to see you are plan to getting back ning to get back out there as soon as you can. good luck and hope everything works out for you.
