Good morning everyone, I am looking for some advice if anybody has time. I bought a 1960 18ft Lonestar El Dorado to restore that will be 100% trailered and used in saltwater. It was the perfect hull style to fit on our limited-space sideyard with a little cabin and about 7ft of standup room in the back for trolling and scuba-diving gear. My previous restoration was a '76 Invader Intruder (fiberglass), and this will be my first aluminum project. I appreciate any help!
1. What size rivets are under the hull? I ordered aluminum 3/16" brazier head, 1/2" long closed rivets. I am wondering if I ordered the wrong size.
2. One the last picture, there's water leaking from this seam. I can't really find which rivet is causing the leak. Is there a special way to find it? Also in picture 8, the keel strips have holes in them I assume are factory. If water is seeping out of one, how do you find the rivet responsable?
3. In pictures 7 and 8, there's 2 pipes riveted to the hull under the seatbase. Anybody know what these are for?
4. The hull has max hp of 80hp. I was thinking about bracing the transom with extra knees and putting a 90hp 4stroke or 115 2stroke. Has anyone done this without the weight being too much?
5. Anybody ever mount a gastank under the deck on a boat similar to this?
6. Most important question that I cannot find an answer to: When I build the deck, should it be bonded to the hull at the edges to allow no saltwater to enter below deck like a fiberglass boat? My concern is if I leave a gap along the edges, saltwater can get down there from fish/wet dive gear and then I cannot hose it down when I return. Initial thought it poly or epoxy PB in the gap then a layer of 1708 (or cloth if epoxy) then paint, but then it won't be easy to remove the deck for possible future leaky rivets. What would you do?
