Long distance towing
insanity
Re: Long distance towing
Inspect the bearings first then if they are good install them fill with greese and go.
robert graham
Check your load, bearings, grease, etc. and distance of haul won't matter. Every rest/fuel stop feel bearings/hubs for heat, check your load, keep on rollin'. I keep a spare tire/wheel, and a spare hub assembly in my trunk just in case. You can buy the entire hub/bearings/seals, all greased and ready to go at Northern Tools for about $30, good insurance! Good Luck!
msojjo
^^^Agree, all you can do is pull off the cover/or bearing buddy check for water intrusion check for play, but if your going to pull them off for an inspection you may as well just replace for a couple of bucks.
Silver Eagle
All the above and make sure that your tires are pumped up to the proper pressure.. Nothing worst then having to change a tire on the road.
LippCJ7
Everyone here is giving you sound advice and I would replace them and install the bearing buddies myself if I hadn't allready done it, you will love them......mostly, what your going to find is that you will want a nice wax on your wheels for the long haul as the bearings will heat up and the grease will break down and leak all over the wheels. A decent wax makes cleanup a snap and you simply pump some more bearing grease back in, piece of cake. I go to Powell once or twice a year, 500 mile trip one way, temperatures range from 90 to 105+ degrees so the bearings take a beating. Good Luck!
