michaelsen
- Joined
- Dec 20, 2001
- 94
I want a 9.9 outboard next to my main motor. I have mounted a bracket on my transom and a short shaft will make it so the plate thingy on the shaft (not sure what it's called) will be in level with the transom bottom where it is mounted, just as it should. If I put a 20" shaft motor on, it will of course go deeper to about the same dept as my main motor. <br />What should I choose? Does it matter at all what size shaft I put on? It's a 18' bow rider and I will use the kicker for trolling and in case my main motor fails. <br /><br />Regards<br />Michael
