The distance from the top of the transom (where I will mount the kicker), to the bottom lowest point on the v-hull is 25.5".
If I'm not mistaken I can either mount an extra long shaft motor (27") directly on the transom or I can install an adjustable kicker mount and use a short shaft kicker. I would appreciate any comments or suggestions (pros/cons) as to which way might be best given there is a choice.
