I have an '83 Evinrude 140 that I want to convert to a long shaft because the current length shaft (20") causes the prop to cavitate with a three bladed prop installed. A four bladed prop causes much less cavitation but the hole shot is BAD! I want to get the 3 bladed prop deeper in the water so it does not cavitate and I found the conversion kit right here locally.
Looking for advice on this idea before I go buy the kit for $200 and find out it doesn't work like I think. Will it just create so much more drag that the conversion is not worth the cost or is this a sound idea?? I do mostly tubing and skiing with the boat and not concerned about top end to much.
For anyone else looking for a conversion kit I found this one at Budget Boats in Chesapeake VA. You can Google them and find out their contact info.
