Long shaft on a 15" transom or a conversion
SSerge
Hello, I'd like the opinion of some of the experts on this site concerning the following. I own a 14' Jon boat, with a 15" transom. I have an opportunity to buy a practically new out board (Honda 15 HP), but it is a 20" or long shaft. Can I replace the lower unit to make it a 15" shaft? If so, how costly would that be? Do I have any other options, or should I just forget it, and look for something with a 15" shaft. Thanks again, looking forward to some replies here.
D
DJ
Guest
Re: Long shaft on a 15" transom or a conversion
It can be done.<br /><br />At the minimum, the lower unit will need to be dismantled to install a new drive shaft. You will also need different cooling tubes and shift shaft pieces.<br /><br />Can't help on the cost.
mjbrueck
You could also get an outboard bracket or jackplate. Something like thisJackplate<br /><br />On a 14' jonboat, with a "heavy" motor, I'd look for one with minimal setback for balance purposes.<br /><br />I just noticed there's no picture on the link I posted. If you do a search on I-boats for "outboard bracket", you'll get lots of hits.
Solittle
Mariner1 - I been running a 1975 long shaft 9.9 Johnny on a 12' alumnium skiff with a 15" transom for years with no problems. I would not run a short shaft on a 20" transom though.
