GarySutherland
- Joined
- Feb 5, 2005
- 12
I've a little 13ft Fletcher speedboat which at some time in the past has had the transom built-up by a couple of inches, presumably to take a long-shaft engine.<br /><br />The engine I want to fit is a 20HP short shaft Johnson. Would it be better for me to return the transom to its original height or won't it matter too much?<br /><br />The top of the cavitating plate is an inch or so above the bottom of the keel when the motor is fitted.<br /><br />Regards<br />Gary
