Longer pontoon placement
buckmeyer
I'm replacing the toons on my 24' Harris. I can get a deal on 25 ' new toons. What would be the best way to position them? The extra 1 foot out the front, back, or split the difference?
Thanks!
cc350
Re: Longer pontoon placement
I'd split the difference:)
boatmor
Most of the time the load tends to be on the back. If you will notice the boats with longer logs always have them out the back.
5150abf
Put it out the back, gas, engine extra furniture back there so the shift in weight can only help.
That is if you have a choice, bracket placement may dictate where they go.
EGlideRider
I would split the difference if the brackets allow.
likalar
If the boat in the water sits level, split the difference. If the stern sits a bit lower than the bow, give the extra flotation to the stern.
Larry
jusfloatin
If all you are talking about is a foot difference in length I would say place the new pontoon where it looks the best the best.
Don't get me wrong as there is probably lots of reasons to either place it ahead or behind when it comes to weight distribution but it realy comes down to looks.
Do you want a foot hanging out the front or the back.
My opinion- center it.
imported_John o
If you leave the extra to the aft you gain more floatation back there AND it gives you space to install additional storage etc.
buckmeyer
Thanks guys...I guess I'll see how the brackets line up. I'm leaning towards shifting them towards the back if possible. Also worried about spray off the front if they are too far forward.
EGlideRider
You will be more likely to get water over the bow if you shift them toward the stern. Remember that you may have several people sitting up front so you don't want the bow too low.
I still recommend that you split the difference.
cc350
It's all about balance. Split the difference. To much up front and the bow rides high to much out back and the stern rides high. Splitting keeps a balanced passenger area.
