Astroquickfire
- Joined
- Jul 11, 2008
- 12
I recently installed surge/disc brakes on my bass boat trailer when I went to a smaller tow vehicle. In order to do this I had to install another axle due to the fact the factory beam did not have brake flanges. The factory axle was a spring under 2" drop, 90" wms-wms. The only axle I could find in the correct width was 4" drop axle. When installed "spring under" it sits too low and the tires hit the fenders on hard bumps. When I tried flipping the axle and running it "spring over" the trailer sits too high and it is very hard to load/unload the boat, I have to back further into the water to get the boat floating.
When I went "spring over" I tried some very short shackles. Still too high. When I had it "spring under" I tried the longest shackles I could find locally which are 3.5" center to center.
I need some 5" shackles to get things as they should be.
Is there a source out there that sells shackles made at those longer lengths?
