Re: LONGIVITY
I'd say it has a lot to do with the shade-tree mechanics of the world, too. If you've got a basic Craftsman tool set and a flywheel puller, you can do just about anything needed to any pre-1960 Johnrude, whereas you need a little more ingenuity to work on a pre-1960 Merc. Even basic maintenance like changing a waterpump impeller requires a special tool, whether it be homemade or the actual Mercury-made tool. Many small Mercs (Mark 5/6, Mark 10/28) had spring loaded clutches and shifting mechanisms that required gauges, tools, etc. to work on - not usually the realm of the shade-tree mech. As such, many of these smaller motors ended up junked because they couldn't easily be fixed. If you knew what you were doing, they could be, but the ratio of those who did and didn't know how they worked was greater for Johnrudes than for Mercs.<br /><br />On the bright side, there's still lots of old motors out there, whichever your preference. There's sources for parts and tools for most models from all three brands, and they all have their followings...<br /><br />- Scott
