Re: longshaft motor on a short transom?
Definitely do NOT use a stablizer plate! Those plates work best when just out of the water while the boat is on plane. If you run them completely submerged they do all sorts of quirky things to your handling...<br /><br />Worst case scenario - motor performs poorly, throws water into the boat, suffer poor mileage, drags the bottom frequently, and puts great stress on the transom with added leverage. <br /><br />Best case scenario - motor runs fine, performs fine, minor issue with fuel mileage, you have a really strong transom that can handle the added stress, and you run in deep water with no danger of hitting bottom.<br />- Scott
