Looking at a 1988 Chaparral 224 with Johnson 200 Outboard - any thoughts?
roadracer4U
I'm looking at a 1988 Chaparral 224 with a 200hp Johnson Outboard. <br /><br />The Good: The hull is in great shape, has sonar, radar, fishfinder, new hydrolic steering, generator, bilge pump, throttle control, mostly rewired. <br /><br />The Bad? It needs a new tilt motor and the compression on the motor straight across all six cylinders is 60psi. However, it has been stored inside for two years and started right up. <br /><br />Does anyone have experience with this boat or have opinions about this motor? Any thoughts are greatly appreciated!
CATransplant
Re: Looking at a 1988 Chaparral 224 with Johnson 200 Outboard - any thoughts?
I'd question the compression gauge you used to measure the compression with. If they're all the same and the engine runs OK, I don't think the actual compression is 60 on all cylinders.<br /><br />I'd try again, but with a different gauge.
roadracer4U
I tested this engine again with a different compression tester, came out 75-80 psi for all cylinders. I did this without warming up and running the engine first. Do I need to run it to operating temperature before testing?
