Looking at a boat but I can't find info about the sterndrive model
89cruisers
Hi there, I am looking at a 1971 Starfire, with a 302 Mercruiser, the uper gear housing is bad, along with the gimbal bearing, looking at this
http://www.sterndrive.info/sterndriveparts/cross_reference_help.html
it appears the stern drive is a 215 4bbl, the serial number on it is 2910038 (model number was unreadable) but I cant seem to find any info on this drive? I know it was bigger than my 165, and this engine takes in water from a outside vent instead of thru the drive. any info would be helpfull. Thanks!
captk
Re: Looking at a boat but I can't find info about the sterndrive model
Sounds like a #2 drive not a MC1 they are lots bigger and all together different from the 1s. several different 2s were offered but this is a place to start good luck Bill
89cruisers
I don't quite get what your saying? what is a 1 or a 2?
captk
Mercruiser made several different drives from the early 60s till today. They were designated by numbers. some were, 1A,1B, 1C. 1 ez shift, 2, 2tr,2trs,215h,215e,and a #3. in the 80s they started the alpha, alpha gen 2, bravo, etc. With the transom mounted water pickup, you have one of the #2 drives.
89cruisers
oh alright, I assumed my service manual covered all mercruiser drives, is there any way of telling which model I have then? I can't buy it until I know how much the parts are going to cost
frank246
Edited
89cruisers
It looks like this boat is still for sale, so im sure he is ready to move it for a good price, does anyone have any more info on this thing?
captk
Lots of good info in that link but I believe you have A 215E, or 215H. Not the #1s that link addresses. They use a Mercruiser 2TR drive and a transmission between the engine and the drive. The transmission is either a velvet drive or a MercTrans2. Parts are real expensive and becoming scarce. The 215E was electric shift, the 215H hydraulic. check out this link. Has some drive pics. http://www.mercstuff.com/howdoi.htm
Ayuh,... Post a Picture of it might help,...
But, from what's in this thread so far,...
You don't want it anyways as parts probably just Aren't available, muchless Super Pricey...
89cruisers
Oh jeeze, yes this is sounding very very expensive, can one just... take the old belhousing off and put like a bravo in its place? or even just an alpha?
Ayuh,... With enough Work,... Ya, that'll work...
Don S
NO! Everything is completely different. The drive is like a TR, no shifting done in the outdrive, and you have a transmission on the back of the engine.
You probably need to avoid that boat all together. Parts for the drive and transmission (if the Merc tranny) are almost non-existant.
89cruisers
Alright thanks guys, I guess this is why that boat is still for sale for so cheap, I will be sure to avoid it... thanks again everyone..now off to look at a wellcraft and a sea ray instead
