A buddy of mine came to me the other day and said his neighbor is looking to get rid of his old Starcraft SS, its a 22ft model, the registration says its a 1979.
The boat was torn down and rebuilt about 8 years ago, new transom, new floors, all new nautilex, and new steering.
The motor is a 225hp Mercury, also 1979.
Lets just say the price is very right, but I'm not too sure I want to take on a possible project. The boat looks great, but it leaks. I took the boat out for about an hour and forty five minutes and it took on about 50 gallons or so of water, with two bilge pumps running. The old guy that has the boat says he coated the whole inside of the hull with Gluvit, which should have taken care of any minor leaks, but this seems pretty severe.
With the boat on the trailer I see no signs of any obvious leaks, no loose or missing rivets, and no aftermarket added holes below the water line. I was running it in light chop in the back bays here and the bilge pumps never stopped running, there's a pair of 1500 Rule pumps, one in the bow, one in the stern.
The boat looks great, its got a professional paint job and the interior is a solid 9 condition wise.
The drain plug is new, the motor bolts are tight with 4200 sealer used around the lower bolts. The boat sits fairly high in the water, it don't seem water logged either.
The guy said the boat had poured in foam when he got it, which makes me doubt the actual year of the hull too. The hull has no lapstrake lines and is white with gray trim with a gray and red interior. I owned an 18' Starcraft SS and that had block foam flotation, I would have expected the same in this model?
The actual year don't matter since its been re-titled here by the Marine Police at some point but I suspect its a newer hull, which may affect how I look at or go about any possible repairs?
Its the leak that concerns me, I have a sneaky feeling that its going to need to be stripped down again to find the leak, when its afloat, I see nothing coming in around the motor or transom area, so the leak has to be up front. The boat was stored in a barn and the bow was 6' in the air when I hooked up to it, and there was no water dripping from the drain area when I first looked at it.
Has anyone dealt with one of these 22' hulls with a leak? Is there any place in particular that is an issue? If it were a few gallons, it wouldn't bother me, but its a lot of water, it took 15 minutes or more for the hull to drain after I pulled it out of the water.
Its not mine, yet, and if I can't find an obvious source to the leak, I'm not sure I want to own it.
