Skiuseme
- Joined
- Jun 18, 2003
- 409
Its been awhile since I have posted here. Just took boat in for winterization and I get the phone call that my Block and Both my manifolds are cracked. I live in a climate where it happens all the time but, this one is a head scratcher too me. From Late October till Early May my boat sits in a heated garage that my family controls along with 3 other boats. The Other boats in this facility don't winterize either as it sits in heated storage and none have had issues. This is a building that we have to maintain at 60+ degrees all year round and no one has messed with furnace this past year. We have alarms at the building if we would lose power and then in turn the power would drop. I winterize change oil, drive fluids and other things every other year. The years that I don't winterize in the spring do a spring tune up that involves oil change fluid things and other fun stuff. Just to make sure that I'm taking care of my baby. This past week I took my boat in for winterization and they give me the call with a cracked block and manifolds..... Great.
I question them about the cracked block and manifolds because if it happened this summer I should have lost performance, Oil pressure should have spiked and also should have been a major issue with the water temp in the motor. None of this happened.... They tell me that because my impeller was that good it would keep up and maintain enough pressure and cooling to not spike the temp and the alarms wouldn't sound....
I question them when they changed oil and other fluids in Mid May this year if this would be noticeable they said it may. I asked to check records and other things, they showed no notes on it to this issue.
Maintained by the same Marina since brand new previous owner owned it for 3 years and I bought from marina in 2006
$10,500 to do the Block, Manifolds and also the Bellows......
Thoughts and tell me am I missing something that could add more clues to this issue(s)?
Details on unit: 2003 SeaRay Sundeck. 219 hours, 5.0 v8 Mercruiser with an Alpha 1 outdrive.
