Looking for Chrysler Distributor Cap
Stevum
To Anyone who can help!!
I am looking for a Center piece of the 3 piece Distributor Cap .(The one with the Contact points)For a 1975 - 75Hp Chrysler 3 Cylinder motor model # 757HB, Serial # 14817. I also need the Carbon Tip Contact & Spring for the Center contact.(I don't know if this is included with the Cap). The inside of the cap I have is Stamped with the # 4007X or possibly #24007X. The cap somehow became loosened & the contact areas were damaged by the rotor, plus the carbon tip fell in the lake when I removed the cap to asses the damage. (Smooth Move, I Know) Any help you could provide is greatly appreciated.
Thanks! Steve A.
lloydlamere
Re: Looking for Chrysler Distributor Cap
I have the exact same need with the exact same motor. The cap I have also has the 4007X imprinted. There are places for 6 cylinders, but only 3 are used and the other 3 blanked off. If you have found where to get this please let me kmow. Thanks
Lloyd Lamere
512 632 3284
Frank Acampora
Gentlemen: New, that cap is not affordable but if you want to spend the big bucks, contact franzmarine@aol.com.
Used, Google the Chrysler Crew and get onto the questions forum. Ask there for a used cap. You might get lucky.
I do have a couple of caps BUT I need to check to see if I have a need for them. I have a lot of engines in parts that are ultimately destined to be reassembled.
If not successful at The chrysler crew, send me a private message in about a week.
