Heres scoop on 92 120 looper with miss problem. did test on timer base or sensor coil as book calls it. Green wire was not showing .5 voltage--zip--zero-- went to ohm test everything checked good -- went back to voltage test green wire showed voltage. Hooked everything back up--motor ran on all four again--boat ramp getting crowded, had to move on. Both timer bases will do same thing on same wire. Can the magnet on the hub of the flywheel have anything like occur or is it all all or nothing when they get weak?<br /><br />Heres scratching my head again
