Looking for Fuel Pump for 90 HP 1987 Johnson without VRO
clarky711
Greetings, a plastic fitting broke on my VRO/fuel pump this weekend trying to pull start the engine (starter broke - ugh). Anyway the VRO has been disconnected for a while (working great mixing in tank) and I was wondering if there are relplacement fuel pumps that don't have all of the VRO stuff. If it bolts up to the factor 3 bolts that would be great. Any websites or part numbers would be helpful. Thanks.
Mike
kencat
Re: Looking for Fuel Pump for 90 HP 1987 Johnson without VRO
This page should help you out - http://www.maxrules.com/fixomcvro.html
Pn# 5007422 looks like a VRO pump without the oil chamber so it should bolt right in. See here for picture - http://www.crowleymarine.com/brp_parts/diagrams/35191.cfm
Cheaper solution is the standard fuel pump, but it may require a mounting bracket to be fabricated and new hoses cut and routed. I'm still trying to find out if the pulse limiter fitting has to be replaced with an open nipple for the standard pumper to work right though.
