Looking for performance exhaust advice for VP 290 DP
roysbb
Hi Guys,
I will need to replace my exhaust manifolds and risers soon.
Is there a performance difference between vendors, models, etc
What other things can I do to improve exhaust flow ?
This is for a chevy 350 with approx 320 HP
Thanks, Roy
volvo manifolds are great right out of the box. you wont gain anything with exhaust a small block until you bolt a blower on it or spin it well above the RPM limit of the 290DP
roysbb
So, does everybody agree that all risers and manifolds are the same?
I just wont buy something without doing a little research.
What about the manifolds that have smooth, individual runners versus the cheap, generic ones?
How about the reversion hook that some risers exhibit versus the ones with a smooth path?
I am sure somebody has some advice on a better brand.
I know there is better efficiency to be had just looking at the Y pipe as a pinch in the overall system.
I am thinking a 454 would have the same power as a 350 if it has to breathe through a single 1.5 inch diameter pipe...
Thanks, Roy
Lubak572
There are other options, hy tek marine makes stainless, and hardin marine has their seaward series. They are pricey though. They would save a lot of weight, and add room in tight engine bays. Not sure they would add much performance, but I am sure it would be some. I will look into this next winter myself.
QBhoy
The difference will be not noticeable I think. Better with head work and a cam is think.
