looking for prop indentity help
KCKracker
i am trying to find a affordable used prop locally and i cant decipher the numbers mine currently is a 14.25x21 on my merc 165. im looking at one the guy says the only numbers are 48 832332 415 21P. i cant find any info on it
ahicks
You don't say if you're happy with the performance you're getting with your existing 21"p prop. If you're happy with it, the the prop you are looking at, with a part number that ends in 21p, should give you similar performance - IF - it fits.
KCKracker
its on the boat i just bought, its great performance wise but its bent up
KCKracker
that number i posted is for one local cheap, trying to find out if its a match to mine
KCKracker
TY!! it says blackmax will that fit a mercruiser 165 outdrive?
Faztbullet
Yes it will fit as BlackMax is Merc's trade mark for their alum series props.....
jimmbo
How old is the old prop? Mercury made some changes to there prop lines in the late 70s, the thrust washers and the hardware at the propnut end differs between the older and newer.
