Looking for proper name for this drive
skinny1965
New to OMC
Want to do a impeller change on drive since it’s off
78 is boat year
Electric shift
Redrig
electric shift stringer is what that is known as .
takes type C fluid in the lower
MFG1970
Be especially careful when dropping the lower unit that you do not break the Electromagnet coil wires. Have some support to keep it from dropping to much or you need to remove the wire running through the intermediate housing in order to remove it safely without damaging it. It cost a lot of money for a new lead wire that goes into the lower bearing carrier. http://www.***********.com/parts/omc-parts/omc-boat-parts.php?year=1970&hp=210&model=TUFM-19E&manufacturer=OMC+stern+drive&section=Lower+Gearcase+Group+120,+155,+210+Hp
Competitor link removed.
southkogs
On your engine there should be a tag that has a model number something like "990234E MT" - that will tell you which model Stringer you have.
A 78 model would not be electric shift.----A 78 model boat might have a 77 model drive with electric shift.
MFG1970
New to OMC
78 is boat year
Electric shift
I believe that is called a Hydro shift or something similar to that. That was the next model up from an electric shift. They did away with the electric shift due to the Default neutral if the coils failed or the boat no longer had power to shift it. The newer model default was then made drive. It took hydrolics to take it into neutral and reveres.
