Looking for right prop size and pitch HELP
Tow Joe
I own a 1977 Glassmaster 18 ft. bowrider with a 140 hp i/o. It currently has a 15x17p prop on it. The boat planes out quickly but has a very low top speed, about 30 mph at 4400 rpm which is within max operating range according to the owners manual. What size prop would I use to get a little more speed out of my boat? Any suggestions would be helpful as I am new to boat ownership.
junior1113
Re: Looking for right prop size and pitch HELP
is that 15x17 alluminum or ss prop??
hwsiii
What are the recommended WOT RPM as well as the gear ratio for your motor.
H
Tow Joe
it is a 3 blade aluminum prop.
Tow Joe
Recommended WOT is 4200 to 4600 rpm as to gear ratio i will have to check and get back to you.
junior1113
open up your wallet and get a ss 3x17p or step up to a 4X16p bout the only way your going to pick up any speed. this is if the motor is running like it should and theres no growth on bottom of hull would also check for water loging. stainless props produce better performance esspecialy top speed
